Hi!
I´m looking for the code for my Porsche CR-1 in my Porsche 993. I imported the car to Germany and I need to know how to get the serial number as well.
Thanks a lot!
Hi!
Thanks a lot!
On a CR-1 you might have to remove the radio and read the serial number off the top of the unit.
Cr-210
Becker
3297
V50090000
Are you sure that is your serial number (all zeros)?
On the off chance that it is... Try 1010
Cr-210
Becker
3297
V50090000
It didnt work I attached pictures.
Cr-210
Becker
3297
V50090000
I think that it I just tried it again an it said "wait". I'm going to leave the ignition on for an hour. Thanks alot!!!!
Cr-210
Becker
3297
V50090000
After about 20 minutes the code screen came back up. Is there another code I can try?
Cr-210
Becker
3297
V50090000
Ah... you gave me "90000" the screen shows "09000".
Let's try 8730
Hello , I purchased a Becker CR-220 on FleaBay , did not come with a code , can you help? Thanks in advance!!!
Model # BE4362
Type- Becker CR-220
Serial# X5017885
Model # BE4362
Type- Becker CR-220
Serial# X5017885
Try 2912
Hi Loren,
I need the radio code for a Becker, Model BE 2582, Serial 15010300.
Thank you
Please read the Lost Radio Code FAQ here
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
