Got it! I got the following results: Type: 4462; Serial # &5042555. Then upon further turning the knob to the right: 24/99 and then CDW Reset. Hopefully this is all you need to help me find the 4-digit radio code! This is a 2000 Boxster, 5-speed manual transmission, Arctic Silver w Black interior, US, 6-cylinder engine, 2.5 liter displacement, Thanks! Barbara
I have a 2000 Boxster with a CR 220 radio/cassette. The battery was changed and I need the radio code. The serial number of the radio: CDC-3 Y1052323. Please help!! Thanks, Barbara[/size][/size][/size]
CDC-3 is CD Changer not the radio.
Please review the Lost Radio Code FAQ here
Try 9150
Thanks!! It worked!! Your help is very much appreciated! Barbara
I did the ignition switch repair last night on my 2002 911 Carrera. I then found out I didn't have the radio card in my owner's manuals. Any help would be greatly appreciated.
Becker 1
Type 4462
S/N: 25016601
24/99 ?
Thanks so much
Landon
Becker 1
Type 4462
S/N: 25016601
24/99 ?
Thanks so much
Landon
Try 9262
Hi Loren... looks like you're the radio code Queen :) would appreciate your help after changing batteries.
2001 Boxster 2.7 5-speed
Becker CR220
Type 4362
Serial Y5023005
Thanks much in advance...
Hi Loren... looks like you're the radio code Queen King :) would appreciate your help after changing batteries.
Becker CR220
Type 4362
Serial Y5023005
Note correction above...
Try 5071
Becker CR220
Type 4362
Serial Y5023005
Try 5071
My sincerest apologies for that grave error and misguided assumption...
You da man... :)
Thanks so much, worked perfectly!!!
Hello, :notworthy: I'm locking for my code
CDR23
model # BE 6612
Serial # 35051136
Thank you for your time and info!
Your radio ..is not coded, in that it needs to have a code entered by the user. The radio is IMMO coded and will only work if connected to the original vehicle... :)
See FAQ:
CDR23
model # BE 6612
Serial # 35051136
Please read the Lost Radio Code FAQ here
The CDR-23 does not require a code (as stated in the FAQ).
Hi, i just bought a 2005 996 Turbo S with Nav and I didn't get any radio code. Can I get a code for it?
PCM 3.0 (PCM 2 OS 3)
System Software 3.0
Device Type 6632
Serial Number: 45047756
Edited by Sam996TTS
System Software 3.0
Device Type 6632
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
I got three radio codes with my car... one in the manual, one noted on a repair invoice, and one written on the radio, and of course none of them work. Here is the data:
Becker CDR 220
BE4462
W5008917
Thanks very much,
Tom F.
Becker CDR 220
BE4462
W5008917
Thanks very much,
Tom F.
Try 3482
