Hi Loren,
My battery on my 996 has run flat and is asking for the code.
Serial # 15086176
24/99
Becker 1
Type 4462
CDR-220
CDP 2081
GAL1 00
Could you please assist me with the code
Hi Loren,
Serial # 15086176
24/99
Becker 1
Type 4462
CDR-220
CDP 2081
GAL1 00
Try 0872
Did this a couple years ago and 4145, 4441 and 4439 not working this go around... which is weird because one of those three worked back then... :(
2002 Tip
CR220
Type 4362
S/N 15000619
thanks,
pete
2002 Tip
CR220
Type 4362
S/N 15000619
thanks,
pete
Try 4541
Hi, apparently the last owner lost the radio code for my car. I would greatly appreciate your help! Thank you in advance.
2001 Boxster S
Type: 4462
Ser: Y5044054
Try 9857
2001 Boxster S
Type: 4462
Ser: Y5044054
Try 9857
Worked perfectly, thank you so much.
Yet another lost radio code request:
1997 Boxster, 5 speed, USA car, built in Germany
Radio: CR-210
Type: R2896 (or maybe R2876? could not read my handwriting...)
S/N: T5003475
Thank you!!!
-John
Edited by boxster_nut
Radio: CR-210
S/N: T5003475
Thank you!!!
-John
Try 4736
I don't have the radio code.
Boxster S 2000
6 speed
CDR220
type 4462
sn: Y5037169
Thanks for your help!!
Scot
Boxster S 2000
6 speed
CDR220
type 4462
sn: Y5037169
Scot
Try 0526
You're the man!!! Works perfectly!!! How do you do it?
Thanks for your help!! I owe you one.
Edited by Yazmon
Radio: CR-210
S/N: T5003475
Thank you!!!
-John
Try 4736
Unfortunately it did not work. I double checked the S/N, and it is T5003475
I did some looking on the net last evening and found a 'decoder' that would provide other possible keys, and I tried: 4746, 4836, 5736, 4848, 5746, 5836, 5846, 4735, 7081, 7091, 7181, and 8081.
None of them worked either. Can you suggest any other possible keys? Or alternatives other than going to the dealership?
thank you!
-John
Radio: CR-210
S/N: T5003475
Thank you!!!
-John
Try 4736
thank you!
-John
Did you use the process in the FAQ to have the serial number readout on the display?
Please do so and give me the correct serial number.
@boxster_nut
4736 is the correct original code for the serial number given. (I've verified this with two separate sources)
Sometimes reading serial numbers from radio displays can give wrong numbers, just due to deteriation of the displays...
I'd remove the radio, and check the serial number printed on the label, attached to the metal casing..
You've explained that you've entered 12 wrong codes.... Did the radio go into time lock?
Hi, Loren, I've got a locked radio in my 2000 S (if you read my last post, you know why already!).
CDR-32
Type: 4667
S/N: Y5022262
Any help would be awesome. Thanks!
EDIT: Nevermind. I'm an idiot and didn't read the "READ ME FIRST" on the 986 main forum page. My model isn't unlockable by serial number, according to the FAQ. My apologies.
Edited by RobR
CDR-32
Type: 4667
S/N: Y5022262
A CDR-32 will not likely work at all in a pre-2003 model year car.
Oh, it works alright. I discovered the code under the mat under the front hood. It was in there with the number for Porsche Assistance on a lovely plastic card.
That particular unit might not have been in the car when it was made, but it most definitely works. Now that I've unlocked it, it works beautifully! :)
