Hi I have had my radio reset and do not have a code.
Is it possible for a code to unlock the radio
The details are:
Becker 1
4367
S/N: Y5024261
Thanks in advance
The details are:
Becker 1
4367
S/N: Y5024261
Thanks in advance
Try 9010
Normal story... Yet another flat battery and now the radio is asking for a code I do not have!
If you could help finding the code that would be great!
Radio detail:
Becker 22
Model number 4467
Serial Y5035037
Many, many thanks!
Dan
From previous post... It's a 2001 boxster s, uk car...
Not sure if relevant...
Many thanks,
Dan
Radio detail:
Becker 22
Model number 4467
Serial Y5035037
Many, many thanks!
Dan
Many thanks,
Dan
Try 5451
The details are:
Becker 1
4367
S/N: Y5024261
Thanks in advance
Try 9010
Loren Thank you much appreciated worked a treat!!!
Becker CR210
BE 2182
ser # V5008351
I got the two tools and pulled the stereo out. I am going to disconnect the battery soon. I see that at least 25 other CR210 BE 2182's have asked, so it must be the serial number V5008351 that gets the code.
Thanks in advance.
Respectfully;
Rapewta
Edited by Rapewta
Becker CR210
BE 2182
ser # V5008351
Thanks in advance.
Respectfully;
Rapewta
Try 9464 ...............
Bruce2010...
You da man!!
Worked first time. Thanks. Once you enter the code... press the "seek" button and
the music is blasting thru the speakers.
HI Loren,
Code 1435 didn't seem to work. Any suggestions?
Thanks for the help
Hi, Need some help with my radio.
Becker CDR 220
Serial # 15009779
Thank you!
Try 1435
I recently disconnected my battery to recover my steering wheel, but I do not have the radio code now that it is back in and the battery is reconnected.
The car is a 1996 Carrera 2.
The radio is a Becker CR-210.
The Serial Number is S1000044. I retrieved this from the instructions listed on this site.
Try 0352
Thank you so much! You saved me a trip to the dealer! That worked on the first try!
Try 0352
CDR 220
Ser # 15050187
Radio code 7108
I don't feel the above code is correct as i have to enter it 3 times, and then it goes into wait mode, and then resets back to wanting the code.
what is odd is i have the factory radio code card and t says the SN # is BE 4462 Y 5037949 which is different from the above, when i hold the TP button in.
Thanks for the help in advance.
CDR 220
Ser # 15050187
Radio code 7108
The radio serial number the unit displays is the correct radio serial number. Likely your radio was replaced and they kept the old card.
Try 8764
