Hi Loren...if you could also help me...
I have a 2000 Boxster witha CDR220 Type 4462 Seri X5036905 CD CDP2081
Can you help me with the unlock code? I changed the battery and couldn't find the unlock code card anywhere.
Ta.
Ta.
Try 3261
or
3259
Thanks Loren. I'll try them as soon as the verkakte "WAIT" instruction goes away - how long will that be?
Please read through some of this thread - that has been explained several times...
Mine is a CDR-220
Becker 1
Type 4462
W5003121
1/99
The card that the original owner gave me has the incorrect serial and code, so I assume that the radio was replaced at some point, or he was given the wrong card at delivery. I'd really appreciate any help you can offer, because I miss my music terribly.
Mine is a CDR-220
Becker 1
Type 4462
W5003121
1/99
Try 0398
or
0396
Mine is a CDR-220
Becker 1
Type 4462
W5003121
1/99
Try 0398
or
0396
Thanks a bunch. You're a life saver. :D
Hi - I lost my manuals and radio card (wisely stored in house, which burned down) in the October San Diego wildfires (Saved the boxster, though!). Forgot this when I recently disconnected battery. Now I can't reactivate radio.
Boxster 2002
CR-220
Type 4462
Serial: 15005427
"24/99"
VIN#WP0CA29862U622175
Thanks alot for any help.
Try 7306
or
7304
Any help would be greatly appreciated...
I had been given code 9962, but it doesn't seem to be working
2001 Boxster
CDR220
Becker Type 1
BE4462
Serial Number 15088673
24/99
2001 Boxster
CDR220
Becker Type 1
BE4462
24/99
Try 9960
or
9958
Boxster 2002
CR-220
Type 4462
Serial: 15005427
"24/99"
Try 7306
or
7304
Loren - Thanks, but neither of those worked (unless there's a trick to entering them that I forgot). Any other possibilities?
Thanks again
Dave Diamond
Boxster 2002
CR-220
Type 4462
Serial: 15005427
"24/99"
Try 7306
or
7304
Thanks again
Dave Diamond
Read THIS THREAD for other ideas and/or solutions...
Loren,
I think you may have answered this, but I can't find the response either here, in the Boxster site, nor the 928 site. Sorry, could you please give me the codes? THANKS
CR-210 Radio Code
Model BE2182
Serial number 5004353
Can you please give me the radio code. It's in a '89 928 S4 track car, as a retrofit.
THANKS Loren,
Gary Knox
Try 6904
or 6902
THANK YOU Loren, I read the preceeding 20 pages, and decided to got up and down from 6904 in single digits. 6905 Did it!! Danke Schon.
Gary Knox
Loren: Neither of these two worked. Any others to put in? THANK YOU.
Please read the previous posts - if the numbers I gave you do not work then you need to contact your dealer or Becker. Last I heard - Becker charges $30.
Hi Lauren. My radio is locked. Can you help a brotha out?
Type: 4462
Serial: 15085371
24/99
1999 Porsche Boxster 2.5
My name is Loren.
Try 3274
or
3272
Loren,
I tried the codes and they didn't seem to work. I'll retry in the morning after the "WAIT" disappears again. I might have mistyped. Sorry about the name mispell. I noticed right after I posted it. I have a friend named "Lauren" as well, so my fingers are just used to typing it. Thank you again for your help.
Mike
Type: 4462
Serial: 15085371
24/99
My name is Loren.
Try 3274
or
3272
Loren,
Mike
Read the other posts here for other options of the codes don't work.
I have a Becker radio model 4462 Serial Number W5011175 in our porsche 911 -1999 and the radio code card that came with the car is incorrect. Can you help?
Try 8378
or
8376
Try 8378
or
8376
2001 Boxster
CDR220
Becker Type 1
BE4462
24/99
Try 9960
or
9958
Thanks Loren - didn't have any luck with either of those codes. I had written 9962 on the side of the unit when I pulled it out two years. I decided to give up and put the blaupunkt back in.
I've read through this whole thread (phew). I guess since I have an older Porsche CR-1 radio without the code I am out of luck?
Dan
'86 928S 5-spd w/LSD
'93 968 Tiptronic
Dan
'93 968 Tiptronic
Get me the serial number and we can give it a try...
Dan
'93 968 Tiptronic
I got two numbers from the back of the unit itself:
POCR-1R0821899
V40821899B
Dan
'93 968 Tiptronic
