Hi Loren,
I do not have the radio code, but have not disconnected the battery yet. Is it possible to retrieve the radio code prior to powering it down?
If not, could you provide a code/s based on the following:
CDR220
Becker 1
Type 4462
Serial Y5039432
-Wayne
Hi Loren,
CDR220
Becker 1
Type 4462
Serial Y5039432
-Wayne
Sorry, the only place the code is besides on the card from the delivering dealer is possibly in the DME Vehicle Info page.
Only about 30% of the cars I have seen actually had that entry in their DME so I wouldn't count on it. Besides you need the Durametric Software, a PST2 or PIWIS to see that information.
Here are the best guesses for your radio code:
Try 3506
or
3504
Hi , I am going to install the ipod connection and will need to disconnect the radio. I do not have the code
it is a 2002 C2 Cab
3.6
the vin is WP0CA299X2S655135
Thanks !
Mike
it is a 2002 C2 Cab
3.6
Thanks !
Mike
Please re-read this thread for how to get your radio serial number (VIN has nothing to do with radio serial numbers).
I have a different problem: I have the card with the Serial# and Code# but the code does not work for some reason...
Type 4462
Serial W5008491
Code 8753
Maybe I can get it to work with a different code...can someone give me a hand this his issue?
Thank you
Type 4462
Serial W5008491
Code 8753
Thank you
Try 7752
or
7750
I tried both of those codes but they didn't work. Do you have any other suggestions? Thanks!
Can you please help me with a radio code?
Becker
4362
25007445
24/99
Try 7070
or
7068
Becker
4362
25007445
24/99
Try 7070
or
7068
Read the thread here.... there are other suggestions...
Hello,
I need the radio unlock code for a 1991 964 Carrera
Model: CD-2
S/NO: PO CD-2 A 06 14719
Thanks.
I have no idea if this will work on the older radios like this.
But here goes...
Try 4985
or
4983
Hello,
Model: CD-2
Thanks.
But here goes...
Try 4985
or
4983
Sorry to ask, but how do you enter 9 and 8. The radio only has 1 through 6 with no second function that I can see.
Thanks.
Thank you Loren but unfortunately neither code 7752 or 7750 worked...any others that I can try?
Thanks again for your help.
Type 4462
Serial W5008491
Code 8753
Thank you
Try 7752
or
7750
Hello,
Model: CD-2
Thanks.
But here goes...
Try 4985
or
4983
Thanks.
Sorry, I don't know that radio well enough to tell you.
Type 4462
Serial W5008491
Code 8753
Thank you
Try 7752
or
7750
Please Read - Read - Read -- I have covered this many times in previous posts here.
I hooked up my Durametric tool and the radio code wasn't in there.
Then I tried some different combinations close to the two numbers you provided.
7071 worked!! Thank you!
Becker
4362
25007445
24/99
Try 7070
or
7068
Well I just figured out Rennlist and Renntech are two different sites, no wonder I wasn't finding this topic.
I replaced my battery and lost the radio, when I bought the car five months ago, I did not receive any documentation nor radio cards.
My Radio is a Becker 1
Type 4462
SN# X5027630
Can someone tell me the codes to try?
Thanks for your help in advance
Randy
Type 4462
SN# X5027630
Randy
Try 9302
or
9300
Lost my Radio Code on Boxter 2001 2.7l
with Becker Model 4362
Sn Y5023577
Thanks for the help. Much appreciated.
Tufle
Try 9134
or
9132
I was finally able to drive for an hour so I can type the code suggested but they don't seem to work, any other suggestions?
