Ok, just a small correction,
CDR220
4462
15008570
(was able to put the new battery in without disconnecting everything by using the battery charger trick someone else mentioned, thou still need a code to do the rear speaker upgrade).
I tried those codes, but neither one worked. I bought the radio used and the guy told me he had the code. I suppose it could have come from a different year (he has a 99).
Model is BE 4462
Serial no. X5023485
Thanks for the help and quick replies!
CDR220
4462
15008570
Try 1968
or
1966
Model is BE 4462
Serial no. X5023485
You can go the original number (4814) and add or subject by 2. Sometimes that works - sometimes you have to contact a dealer or Becker.
Hi.. I recently purchased a 2001 Boxter. 5 speed with the becker cdr 220 radio and I can't find the radio code card with my owners manual give to me.. Since I am now the 4th owner.. Someone must have tossed it away..
I am planning on removing the head unit to install an MP3 cable from Becker and I know that if the radio is accidentally unplugged it will no longer work. I looked up the serial number using the Becker 1 display prompt on the unit and it is CDP2081 Your help is greatly appreciated. Harry
Hi.. I recently purchased a 2001 Boxter. 5 speed with the Becker cdr 220 radio and I can't find the radio code card with my owners manual give to me.. Since I am now the 4th owner.. Someone must have tossed it away..
4462
serial #Y5052857 You help with this code is greatly appreciated..
4462
Try 6717
or
6715
Can you please help. I have lost my card and need the radio code for:
1997 993 Cabriolet
CDR-210
Serial #T5000861
Thank you!
K.
Try 0713
or
0711
Thanks...it was 0715! You just saved me so much trouble.
4462
Try 6717
or
6715
Thanks. you are a lifesaver... I love this site..
Loren,
I removed my battery and when I returned back the battery the radio re set it self and asking a radio code.
Please I need help.
Radio Type: CR-220
Model # BE4362
Serial # X5017432
Maker: Becker Automotive System
Please help!
Loren,
Please I need help.
Radio Type: CR-220
Model # BE4362
Serial # X5017432
Please help!
Try 6966
or
6964
Due to several attempt a while ago. The Radio appear the word WAIT! How can i re set the radio?
Please.... READ READ READ.
This has been answered numerous times already in this same thread.
Hi Loren,
Im new in this site! I been looking for the link and thread to re solve the WAIT! can you just help me to link to this solution. I really appreciate your big HELP!
Thanks a lot!
Louie
Loren...I finally need your code help. Ive read all your past posts and am up about 3 hours in wait time. Help?
98 Boxster
CDR-210
W5020950
98 Boxster
CDR-210
W5020950
How are you waiting? The wait time is "drive time".
Try 5009
or
5007
98 Boxster
CDR-210
W5020950
Try 5009
or
5007
HAHA..you are correct...dfrive time for the first 2 hours...now it is sleating and snowing a bit. I'll give these a try. Thanx SOO much.
98 Boxster
CDR-210
W5020950
Try 5009
or
5007
Loren, Tried the 2 codes ..no luck..any other thoughts? Again thanx for your time and help.
98 Boxster
CDR-210
W5020950
Try 5009
or
5007
You can go the original number (5009) and add or subject by 2. Sometimes that works - sometimes you have to contact a dealer or Becker.
