Lost Radio Code - post your request here
Mine is a CDR-220
Becker 1
Type 4462
W5003121
1/99
The card that the original owner gave me has the incorrect serial and code, so I assume that the radio was replaced at some point, or he was given the wrong card at delivery. I'd really appreciate any help you can offer, because I miss my music terribly.
Mine is a CDR-220
Becker 1
Type 4462
W5003121
1/99
Try 0398
or
0396
Mine is a CDR-220
Becker 1
Type 4462
W5003121
1/99
Try 0398
or
0396
Thanks a bunch. You're a life saver. :D
Hi - I lost my manuals and radio card (wisely stored in house, which burned down) in the October San Diego wildfires (Saved the boxster, though!). Forgot this when I recently disconnected battery. Now I can't reactivate radio.
Boxster 2002
CR-220
Type 4462
Serial: 15005427
"24/99"
VIN#WP0CA29862U622175
Thanks alot for any help.
Boxster 2002
CR-220
Type 4462
Serial: 15005427
"24/99"
Try 7306
or
7304
Boxster 2002
CR-220
Type 4462
Serial: 15005427
"24/99"
Try 7306
or
7304
Loren - Thanks, but neither of those worked (unless there's a trick to entering them that I forgot). Any other possibilities?
Thanks again
Dave Diamond
Boxster 2002
CR-220
Type 4462
Serial: 15005427
"24/99"
Try 7306
or
7304
Thanks again
Dave Diamond
Read THIS THREAD for other ideas and/or solutions...
Loren,
I think you may have answered this, but I can't find the response either here, in the Boxster site, nor the 928 site. Sorry, could you please give me the codes? THANKS
CR-210 Radio Code
Model BE2182
Serial number 5004353
Can you please give me the radio code. It's in a '89 928 S4 track car, as a retrofit.
THANKS Loren,
Gary Knox
Try 6904
or 6902
THANK YOU Loren, I read the preceeding 20 pages, and decided to got up and down from 6904 in single digits. 6905 Did it!! Danke Schon.
Gary Knox
Loren: Neither of these two worked. Any others to put in? THANK YOU.
Please read the previous posts - if the numbers I gave you do not work then you need to contact your dealer or Becker. Last I heard - Becker charges $30.
Hi Lauren. My radio is locked. Can you help a brotha out?
Type: 4462
Serial: 15085371
24/99
1999 Porsche Boxster 2.5
My name is Loren.
Try 3274
or
3272
Loren,
I tried the codes and they didn't seem to work. I'll retry in the morning after the "WAIT" disappears again. I might have mistyped. Sorry about the name mispell. I noticed right after I posted it. I have a friend named "Lauren" as well, so my fingers are just used to typing it. Thank you again for your help.
Mike
Type: 4462
Serial: 15085371
24/99
My name is Loren.
Try 3274
or
3272
Loren,
Mike
Read the other posts here for other options of the codes don't work.
Any help would be greatly appreciated...
I had been given code 9962, but it doesn't seem to be working
2001 Boxster
CDR220
Becker Type 1
BE4462
Serial Number 15088673
24/99
Try 9960
or
9958
Thanks Loren - didn't have any luck with either of those codes. I had written 9962 on the side of the unit when I pulled it out two years. I decided to give up and put the blaupunkt back in.
I've read through this whole thread (phew). I guess since I have an older Porsche CR-1 radio without the code I am out of luck?
Dan
'86 928S 5-spd w/LSD
'93 968 Tiptronic
Get me the serial number and we can give it a try...
I got two numbers from the back of the unit itself:
POCR-1R0821899
V40821899B
Dan
'93 968 Tiptronic
