12 minutes ago, Loren said:
From the Lost Radio Code FAQ ...
"I get a WAIT on the display - what do I do?
You have to wait at least 30 minutes before trying again."
Thank you, but no other code options. Tried 6530 twice. Thank you
10 hours ago, Matt A. said:
Any other ideas:
Becker 1
type 4466
Serial: X5844535
6530 didn't work, thanks again 🤞
"The suggested number did not work - what do I do now?
Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work."
Than you. Please try serial: X5011535
1 hour ago, Thomas felbo said:
Hi, do you have the code for a
be 7993
85006522
thanks Thomas
"Which radios fitted to Porsche can have their unlock code recovered through serial number?
- CR-220/CDR-220 - Becker
- CR-210/CDR-210 - Becker
- Traffic Pro NAV/CD - Becker"
