3 hours ago, sasilverbullet7 said:
Hi, I have a 2001 Porsche with nav.
Can I have the code please?
On the side tag:  FB5WX78004
S/N:  P0804010482503 the last two numbers may not be correct, best I could do at the angle I was looking.
The last two numbers are important.
Try 8734
4 hours ago, Barry27 said:
Looking to retrieve code for Becker CR 220.
serial # 15050434
BE 4362.
Any help would be greatly appreciated!!!
Try 4978
4 hours ago, Garage_allys said:
Hi, I have a 2001 Porsche with PCM
Vin number : WPOZZZ99Z1S601162
Thanx...
From the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Thank's for the information....👍
Good afternoon, thank you for this awesome service!! I have recently purchased a 1999 911 and need the radio code if possible.
Becker CDR 210
type BE 2282
serial # W5019519
Becker CDR 210
type BE 2282
serial # W5019519
Try 8787
Purchased a used Porsche and the radio code was not included. Would appreciate any help.
Model: CR-220
Type: 4362
Serial #: X5018175
47/98
thanks!
Model: CR-220
Type: 4362
Serial #: X5018175
47/98
thanks!
Try 9569
Hello!
Did not get the code for the radio when buying my 986, battery disconnect and you know the rest!
Becker 993.645.119.01
Type: CDR 21
Model: BE 2280
Serial: V5007234
Many thanks in advance!
2 hours ago, freand85 said:
Hello!
Type: CDR 21
Model: BE 2280
Serial: V5007234
Try 4630
57 minutes ago, Loren said:
Try 4630
Thank you so much Loren, you are a lifesaver! It worked like a charm.
Hats off to you good sir.
22 minutes ago, Jowalston said:
My becker radio appears to be 44/00
Serial number P080400104825108
Searching for radio code
That is not a number I recognize - is this a PCM?
8734 wasn't it.
Here's some pictures to help figure this out:
It's a BE2582
There will be a code for placing and another for navigation - I think...
Many thanks!
Michael
Model BE2582 is PCM.
3 hours ago, Witterings said:
Any chance of getting a code for a CDR 32
Model No. 4667
Ser No. 15000533
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
