23 hours ago, Loren said:
Did you use the Lost Radio Code FAQ procedure to get your serial number?
If not then please follow the procedure and re-post. If you did then chances are your radio has not been repaired by Becker but has been repaired by some 3rd party. In that case I can not help you.
I did.  It display Becker 1 then also displays Type 4462, if that matters.
6 hours ago, Mike2000 said:
Hi need a radio code
2002 Boxster
CRD 220
BE 4462
SER # 15004025
Thanks for your help
Try 5041
2001 Boxster S
CDR 220
BE 4462
SER # Y5046259
Thanks for your help 🙂
Try 5020
  • Like 1
21 minutes ago, Hadi said:
I got. Cdr220 with a serial number y5034018 and not sure what the code is already got a wait message
Try 4985
  • Thanks 1
First post
Thanks for your consideration.
I have a 1998 boxster base with a CDR-210 radio.
The imprint on the side is stamped BE2282W5019032
Any help with determining the code would be appreciated!
Also does anyone have a spare radio button (black button with the small white donut behind the button)? I removed one of the buttons in the photo to show the white donut behind the button.
25 minutes ago, zkspyder said:
First post
Try 1571
Lost the radio when working on the porsche i bought recently, your help with codes is greatly appriciated
CDR-220
Type: 4462
Ser: 15087621
20 minutes ago, anix986 said:
CDR-220
Type: 4462
Ser: 15087621
Try 9232
9 minutes ago, Ronnie Sekishiro said:
Do you have a different one? Didn’t seem to work.
