Hi - I replaced my battery and now my radio is looking for a Code.  It’s a type 4362 and the serial number is 25007344. Appreciate any help to get the radio working again!
Try 9094
Just purchased and dealer put a new battery in my 2002 996 C4.  Code is nowhere in the car and original manuals book where the card may have been located wasn't included with car.  Check of the boot and spare tire area was fruitless. CR220 Radio R15701835.  Can you help?
Try 6732
  • Thanks 1
1 hour ago, Naomi Kingston said:
I had to replace the battery and now my radio is dead.  Can anyone help figure out the code?
BECKER 1
Type: 4462
Serial: Y5050939
24/99
Many thanks!
Try 4923
  • Thanks 1
Lost radio codes. Just bought the car a few days ago. And the radio is locked up
2000 boxster
cdr 220
# y5043294
type 4462
Edited by nathan fast
2000 boxster
cdr 220
# y5043294
type 4462
Try 2535
  • Thanks 1
Is there a faster way to bypass the wait signal to enter the code?
From the Lost Radio Code FAQ...
I get a WAIT on the display - what do I do?
You have to wait at least 30 minutes before trying again.
  • Thanks 1
Thank you. So much. I’ll leave the radio on. And displaying that see what happens
40 minutes ago, Neil Sweeny said:
Sorry. That didn’t work? Any other codes? Thanks
If you gave me the correct serial number that shows in the display when queried then it is likely that your radio has been repaired by a 3rd party (other than Becker). In that case I can not help you - perhaps Becker?
Hi Lauren, battery change, need code for a CDR210 model BE 2282 S/N w5024556
thanks, burns
Edited by burns334
