Hi!!! Thank you for your work here!!!
99 boxster lost radio code [emoji4]
CDR 220
Type 4462
Serial W5002283
Much appreciated!
- [emoji258] shawna [emoji255]
CDR 220
Type 4462
Serial W5002283
Much appreciated!
Try 2637
  • Like 1
Hello,  Very grateful for any help!
1999 Boxter
Becker CDR 210
Type: R 3297
S/N: V5011131
Appreciatively,
AlexQS
1999 Boxter
Becker CDR 210
Type: R 3297
S/N: V5011131
Appreciatively,
AlexQS
Try 4542
Hello,
Trying to keep the 996.2 Bose system with Becker radio and the 2nd hand replacement unit came without codes.
CR 22
BE 4367
Y5030237
BR,
Jussi
6 hours ago, piethein said:
Hello,
CR 22
BE 4367
Y5030237
BR,
Jussi
This is your third request for a different radio code - please consider a donation to this site.
Try 2649
2 hours ago, Artporsche said:
Help new to me 1999 Carrera 4 dead battery and radio says wait.
How do I get code
CR 220
becker 1
type 4362
47/98
X5013531
Try 8768
I found that number written on the paper option tag on underside of the bonnet.  I did try it but it didn't work.  Do you have to hit enter after.
thanks for the help.
art
art
No.
If the code I gave you did not work then chances are that your radio was repaired by someone other than Becker. If that is the case then I can not help you... sorry.
19 minutes ago, oneeyedthomas said:
Just bought a 1999 boxster
Radio # WSOO7525 (LCD messed up, the second O may be incorrect)
VIN# WP0CA2982XU627459
Thank you for any help.
Try 1296
Can I bug you if you have a free moment to help me find my code?
2002 996 Turbo
CDR-220
Serial #: 25011950
Thanks in advance
Try 2649
Thanks.
Code worked like charm.
Donation done for a good cause.
BR,
Jussi
Edited by piethein
Code worked.
I am looking for a code for my 996TT
CDR23 = eda5f2deef8abbs
Radio = BE661225017063
Any help would be appreciated.
Thanks in advance.
Sam
2002 996 Turbo
CDR-220
Serial #: 25011950
Thanks in advance
Try 4821
5 hours ago, Sam Newman said:
Thanks in advance.
Sam
Hmm... didn't read the Lost Radio Code FAQ...
CDR-23 (or later):
I also have a request for a radio code. The vitals are as follows;
Model. CDR210
Ser No. V5010232
Any help will be greatly appreciated.
Model. CDR210
Ser No. V5010232
Try 2609
