Hi - Same problem, need a radio code...Pleasee.......
Backer Model - BE2580
SERIAL NO:- 15083044
Help is much appreciated!
Thank you!
Thank you!
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
10 hours ago, dvalente27 said:
Hi Loren.
Could you help with a code? But It's an Alpine Mercedes.
model CM2396
p/n A 003 820 6086
s/n AL 2396 V 02 89241 C
Thank you.
You did not read the Lost Radio Code FAQ... we can only get codes for the radios listed there.
Hi Loren,
Greeting from Finland, There would be problems with the Porche Boxster  2001, cdr-220 radio. Porche came to me from the United States to Finland and the code was lost.
type 4462
ser  W5002379
Sincerely, Kari
Thank you
3 hours ago, Kari said:
Hi Loren,
type 4462
ser  W5002379
Sincerely, Kari
Thank you
Try 0574
Hi......lost code 2000 Boxster S....Becker 1. Type 4462  Serial # Y5041453    So far I have tried 6401 6403 5650......thank you very much, Randy
Try 4940
Hi Loren,
I got another Boxster, a 2001 S. Can  you provide me the radio code?
Becker CDR 220, Type 4462, Serial Number 15087566.
45 minutes ago, Jager said:
Hi Loren,
Try 5208
Lost my radio code, let me know if you can help.  Thanks
Becker CR-210
R1996
Radio serial number:
Vs005535
Edited by Jrfishel1
Becker CR-210
R1996
Vs005535
Try 5340
Yet another radio code required - put on a new battery last week and had assumed (wrongly) from the number of dead battery starts without the need for re-inputting the radio code that it was somehow linked to the alarm code.  However,  this time with even less information than usual as the label is missing from the head unit!
I do know it's a CR22.
On the inside of the unit's snap off top cover the series 3300/1277.073b is stamped.
There is also a small bar code sticker with the number 436712923902593362
No much to go on, I know, but any help appreciated (even if its just recommending a replacement inexpensive head unit that will interface with the CD changer!)
Many thanks
7 minutes ago, Dav said:
Many thanks
Please read the Lost Radio Code FAQ for how to obtain your radios serial number electronically.
