Hi, a request from England.
Got my Boxster 986 2001 out of the local garage (they fixed some electrical issues), and the radio was reset. As I bought the car second-hand, I was never given the code, so now I am stuck.
Following your instructions I got the following:
Porsche CDR-22
Becker 1
Type 4467
Serial Y5035863
Your help with the code is really appreciated.
Try 3115
or
3113
Hi from Arizona
Bought this 99 Boxster in LA 2 months ago.
Left lights on, battery dead.
Radio code I have no worky.
Becker Radio
CDR-220
Type 4462
S/N W5006268
Thanks! :thankyou:
Edited by Bruce999
Hi Loren
I have a cdr23 and the shop says I need the security code before I can install a replacement
can u help retrieve the security code?
alternatively I'll have to go to the dealers and pay for it : )
thanks
cg
Hi Loren
thanks
cg
Please read the FAQ - The CDR-23's are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. Only a dealer or shop with a PST2 or PIWIS tester can replace a MOST bus radio (i.e. CDR-23, CDR-24).
Porsche CDR-22
Becker 1
Type 4467
Serial Y5035863
Try 3115
or
3113
Unfortunately neither of these two codes (3113 & 3115) worked, and following your suggestions I also tried 3117, which also failed (so now the radio is locked again to WAIT).
Anything I did wrong? Any other suggestions?
Thanks in advance for coming back
Porsche CDR-22
Becker 1
Type 4467
Serial Y5035863
Try 3115
or
3113
Please - read the FAQ.
Tried to use codes 2351 and 2349
did not work .I really want to thank you for your help.
you are not getting paid for this and yet you still want to help.
thank you anyways . you are still cool in my book . Dr. Rick
Thanks - be sure and check the FAQ for more tips...
Hi
I need the radio code
my stereo is a Becker Porsche CDR - 210
Serial Number: V5016131
Thank you so much for any help.
Edited by James Hepting
Hello Loren,
Asking for your help on a radio code:
Becker 1
Type 4462
24/99
Serial #: Y5039995
Thanks in advance!
