I'm new at this so I hope this is the right place to post.
Can someone help me with my radio code.
2002 996 Cab.
CR220
4362
serial number 15003873
I found this helpful place.
Last year I bought a Boxster 2.7, 2001, reimportet from Texas to Germany.
After a long winter the battery was empty and I can't find the radio code
It is a CDR220 - Type 4462
Serial Number Y5053398
It would be great to get help from you
Thank you very much from Aachen
Gerhard
Gerhard
Try 0534
or
0532
Try 0193
or
0191
0193 it is...awesome, but boy did I freak out when the damned thing shut itself off and didn't turn on again until I had removed the ignition key and restarted. I thought you had slipped me a self-destruct-code....
Hi Loren,please help
I got a 986 1998 US with CDR-210,with no code and looked into DME, with PST2-no code.
Serial number W5018983
I couldnt find a model nr.,
found on radio-2282B50W5018983,if helps.
others are damadged.
I read the faq,but it wont come out of the radio(model nr.)
part nr. on radio starts with 993.???others damadged
Thank you anyway
Try 7593
or
7591
Hi Loren,only for stats,codes didn't work,10 codes up and 10 down like faq says,I will go to dealer.
thanks anyway
How did you get the serial number by the method in the FAQ? or from some other document?
it is on sticker on the radio,but others are damadged.will try again tommorow with buttons for number.but I_did try few times before.thx
Hi,I did get the serial number from radio now-it's the same like that one on radio,and was able to get model nr.
R2595
just in case for other code.
thx
Thank you anyway
Try 7593
or
7591
thanks anyway
R2595
thx
Sorry, I think you will need to talk to a dealer or Becker.
Thank you anyway
Try 7593
or
7591
thanks anyway
R2595
thx
ok
I will report you what I'll get
i have lost my radio code. Any help would be appreciated.
Boxster S 2001
Becker CDR 220
Modell:BE 4462
Serial:15062631
Thank you!
Kai
Hi Loren,
I was hoping you could help me. I had to replace my battery but have lost my radio code.
Radio CDR220
Type 4467
Serial X5020446
Iain
Thank you anyway
Try 7593
or
7591
thanks anyway
R2595
thx
ok
Hi,my buttons up and down-seek wasnot working until today when I tryed again few times.the car stood for 2-3years maybe that was the reason.the code was 7594.
:renntech:
Hello there,
I bought my car used and it didn't come with a radio code. Just disconnected the battery to do an electrical fix.
Serial-Nr: W5024517
Model: CDR-210
Thanks for you help!
