johnnyv211 - this is what happens when you post your request(s) 6 times (AND IN ALL CAPS) - plus sending me several emails.
No codes for you - you are not welcome here.
Loren,
Had to swap out my battery and as a result radio needs a code. CDR220 serial number 15001411.
Thanks in advance if you can dig up the code.
Howard
Loren-
Once I got the correct serial number, the code worked. Thanks so much. I wish I had looked for the serial number - using your method - a lot earlier!
Ceilylou
Loren,
I just bought my 2002 Boxster S and it didn't come with the radio code. Any help is very much appeciated!
cdr-220
Becker 1
model 4462
serial 25013325
thanks
Matt
I need a radio code for my 2000 996. The battery died... please help!
Becker 1 CR-220
type: 4362
s/n: X5019995
47/98
Thanks in advance and great forum.
Matt
