Bought 1997 Boxster used so no radio code. Help please
Becker
2896
CR-210
T5002759
Thanks in advance!!!
Try 2349
or
2347
I tried the codes. The radio doesn't come on. the #2 flashes. Do I need to press something else??
Thanks again
Do I just turn on the radio and enter the #'s? Will it come on then or do I have to do something else?
Becker
2896
CR-210
T5002759
Try 2349
or
2347
Thanks again
If you enter the 4 numbers and the code works the radio will start in a few seconds -- if you enter the 4 numbers and it does not start then the code is wrong.
Hi Loren,
The battery in my 2001 Boxster S battery went dead when I accidently left the lights on overnight, and my Radio is now displaying a screen asking me for a code, which I do not have.
I followed the procedure for obtaining the radio serial number in your post, and obtained the following info:
Type 4362
Serial # 15050528
24/99
Your help will be much appreciated.
Jim
Hi Loren,
Type 4362
Serial # 15050528
24/99
Jim
Try 0129
or
0127
The battery of my '99 C2 Cabrio got disconnected and I realized the the car radio card that I was given doesn't match my radio.
It is a CDR-220
BECKER-1
Type 4462
S/N Y5048932
24/99
Grateful if you could calculate a code for me!
Michail
Try 3601
or
3599
Unfortunately it didn't work :-(
M.
Please read the FAQ.
3602 worked!
So it seems that the FAQ needs to be augmented with the info that the code from the 4 digit Becker calculator +1 should also be tried.
Best,
M
:oops: Misplaced code. Help appreciated
'02
911 Carrera/ M 96/03
Black Interior
Tiptronic
LHD
Becker 1
mod: 4362
s/n: 25007995
Try 7375
ot
7373
Though it has taken a while, I am getting back to you to say thanks. I got a variation of the code to work (as suggested in your FAQ).
:renntech:
Boxster radio code needed. Please help.
CDR220
Becker 1
Type 4462
Serial Number Y5047629
Thanks alot for your help!
