Hi Loren,
I have a 2000 Boxster S, and I'd like your help with the radio code.
CDR 22
BE 4467
Y5026629
Thanks in advance!
Dave
Try 9484
or
9482
Code was 9486. Thanks for getting me so close - much appreciated.
Cheers,
Dave
Hi Loren,
Radio code needed for 1998 Boxster
Radio CR210
Model # 3297
Serial # W5020138
Question: I need to perform some service work that requires disconnecting the battery. But before I disconecct it, can the correct code number be verified? What are the step by step instruction to reinable the radio once the battery is reconnected?
Thanks for your time.
Hi Loren,
Radio CR210
Model # 3297
Serial # W5020138
Try 8272
or
8270
Hi Loren,
Radio CR210
Model # 3297
Serial # W5020138
Try 8272
or
8270
Thank you for the code numbers.
I just changed the battery on my 2000 911. I need
radio code but I do not have the card. It is cr 220 with sn #
X5020252. Type is 4362. Any help will be appreciated.
Edited by etmd1
Try 2768
or
2766
Can't find my radio code. Can you help?
CDR 220 SN x5017669
Scott
Try 9614
or
9612
Nope. No joy[Edit] Re-read the FAQ and tried 9616. That worked, Thanks alot!! :)
Scott
Edited by sbelles
didnt work
was i supposed to press something after entering numbers?
now it says wait???
thanks
-thijs
HI
just bought a '98
stoked......
heres the info
CR-210
R3297
W5011419
this would be my
best x-mas present this year by far,
Try 4666
or
4664
