A parking attendent let my 2000 Boxter's battery die. After the battery was recharged I notced the radio was off. I tried to turn it on...nadda. I can't even get to a lost code request as the radio will not even power on, at all...period. Is this something anyone else has experienced? There is nothing I could find in the manual about this issue. Suggestions?
As I said in your PM... please read the FAQ.
Please read this and follow the instructions...
Please help Loren :) Usual story of dead battery and no code!
Cdr 22 boxster
Model 4467
Serial Y5021929
Many thanks in advance, going to have a browse round the site now, ive just come across it.
Cdr 22 boxster
Model 4467
Serial Y5021929
Try 4651
or
4649
Hi Loren,
This is from a 2000 Porsche C4.
Serial number: x5019343
Type 4362
I tried the code that the private party seller gave me which is 0360 but that didn't work. Can you provide the code for my radio? I would really appreciate it if you can. Thank you!
Regards,
Jam
Hi Loren,
Type 4362
Regards,
Jam
Try 5626
or
5624
I need a code for a CR-1. I'm not sure how to get the ser# for the thing but it is asking for a CODE. I've searched for any info on the CR-1 and it is slim to none. It is in 1995 993 C4. I appeciate any help.
I believe that is a 5 digit code - if it is (and you give me the serial number) I'll give it a try.
I'm still trying to figure out how to get the ser# without ripping it out of the dash, the digits must be 1-6 no zeros or 7 8 or 9.
Well I managed to rip it without gouging anything too bad and the serial number is POCR-1R0420292
V40420292B
Part no. 993.645.104.00
BTW the guy at swstereo.com was very nice and talked me through getting the unit out but did not have a code. Good guy.
Ok, try 46672 - good luck!
Unfortunately it would only take 4 digits now it is not asking for the CODE...aaarrggh..if it had a neck I'd wring it. Thanks for the help, G
Hi Loren,
Type 4362
Regards,
Jam
Try 5626
or
5624
Hi Loren,
I tried both but it didn't work. Here's more information on my radio.
Becker 1
CR-220
Is there another code that I could try. Thank you!
47/98
Hi Loren,
Type 4362
Regards,
Jam
Try 5626
or
5624
Hi Loren,
Becker 1
CR-220
47/98
Did you read this?
Hi Loren,
Type 4362
Regards,
Jam
Try 5626
or
5624
Hi Loren,
Becker 1
CR-220
47/98
Did you read this?
I just read it. OK, I will try other numbers that is close to the code you gave me. Again, many thanks!
Same Soup. Replaced battery now no radio, looking for code. Heres the information
Becker 1, 4462, 1506 1984, 24/99
Any help would/is appreciated
Try 8675
or
8673
Try 8675
or
8673
didnt owrk, tried the two number step each way, didn't work, anu other suggestions? Thanks, Mike
Dear
Can you plse provide code for
1997 Targa
Becker
Vers R1996
Serial T5001303
Paul
Try 6570
or
6568
Loren,
Neither of these numbers seem to work.
Any other suggestions?
Does it make sense to try numbers closeby or can it be any number?
Paul
BUMP: think i might of got lost in the guy whose codes dont work
Do you have codes for European Boxsters?
Type: Traffic Pro High Speed
Model BE 7820
Serial 45047009
Model BE 7820
Serial 45047009
Try 1261
or
1259
Model BE 7820
Serial 45047009
Try 1261
or
1259
Thanks but it seems to want a 5 digit code
It will only accept digits 1-7 too there is no 8 9 or 0
I have an old Traffic Pro still in a box that I never put in. I think this was replaced by the high speed version. My old version uses a 5 digit code, and it looks like yours as well.
Problem is the decoder is not accurate, and so old by now that it may be very inaccurate. But give it a try.
If your serial number ends in 7009 then the decoder says the code is 71261.
71261 didnt work im afraid - thanks anyway
