Loren, I have two radios... one in which I am trying to replace (a CR 220 - SN W5007033 Becker 4362) to a CDR 23 Becker 6612 SN 25025993. I was given the CDR23 but don't believe it will work in my 1999 996. Either way. since I have disconnected my old unit and new unit won't work properly.... powers up but fades and repowers up. The new unit will not ask for a code... hence I believe it's not working right.. :) so I am attempting to re-install my old unit but I don't have the code for it... (bought car used with no manuals or codes). Help... :)
Douglas Hrabal-Cox
PCA # 2008070223
Douglas Hrabal-Cox
PCA # 2008070223
Correct a CDR-23 is MOST (fiber optic) and will only work in MY03 and newer cars.
For the CDR-220 try
1453
or
1451
Hi there! Hoping you can help. I just had my battery changed in my 2001 Boxster tiptronic and THOUGHT that I had the radio code. The previous owner had written it in the maintenance manual, but it didn't work. Can you help? The Serial Number is W5002498. Thank you!!
Try 8692
or
8690
Douglas Hrabal-Cox
PCA # 2008070223
For the CDR-220 try
1453
or
1451
Loren, Thank you. I will re-install the original unit and look for a CD Player that will work with my year 996. As for the CDR23 Mod.6612 SN. 25025993 can you tell me what the code is for that also.
Thanks again.
Douglas Hrabal-Cox
PCA 2008070223
Douglas Hrabal-Cox
PCA # 2008070223
For the CDR-220 try
1453
or
1451
Thanks again.
Douglas Hrabal-Cox
PCA 2008070223
Douglas Hrabal-Cox
PCA # 2008070223
For the CDR-220 try
1453
or
1451
CDR-23 is linked to the car with a PST2 or PIWIS tester - it does not have a code.
Sorry for the posts in the other area, was hitting new topic and not checking the board
CR 220
Type 4362
Ser # 15000079
Try 4216
or
4214
4216 was the number, thanks for your patience Loren
I am new owner of used car 99 Boxster, five speed
Cr-220
Type 4362
Serial number W5007612
Speakers in the doors are not working, any suggestions
Blaine
Cr-220
Type 4362
Blaine
Try 5574
or
5572
Hi there,
Need your help... I have a 98 Boxster that had a dead battery. After changing it the radio is asking for a code. The following is my info:
CDR-210
Ser#: V5017335
Thanks in advance!
Jesse ;)
Hi there,
CDR-210
Ser#: V5017335
Thanks in advance!
Jesse ;)
Try 9022
or
9020
