You are amazing. Thanks!
Same and common issue.. why doesn't owners write this code down in the manual or something. Hope you can help
Becker 4462
radio SN Y5046187..
I tried 6401, 6403, 6404
I am back to wait..
Wayne
Try 0860
or
0858
Just like magic.. you are great.. the first code worked.. THANKS
Hi, I have a 99 Boxter with locked stereo after disconnecting the battery for transport...
Becker 1
Type 4462
Ser X5021372
Any help would be greatly appreciated!!
Try 0706
or
0704
0708 did the trick (as per your FAQ). Thanks!
I wonder if anyone would be kind enough to help me... I have fallen victim to the lost radio code conundrum after a battery failure.
The car is an '01 S
The stereo is: CDR-220
Serial: Y5024619
Series: 4362
Any help figuring this out would be much appreciated.
Cheers!
The car is an '01 S
Serial: Y5024619
Series: 4362
Cheers!
Try 0601
or
0599
The car is an '01 S
Serial: Y5024619
Series: 4362
Cheers!
Try 0601
or
0599
0601 was the ticket.
Thanks so much.
Had to disconnect my battery and now the radio is locked.
CDR-220
4462
X5025056
Thanks in advance.
CDR-220
4462
X5025056
Thanks in advance.
Try 9185
or
9193
Thanks for the quick reply, Loren. Neither of those codes worked...any other suggestions?
My battery died and now my radio is locked:
2002 Boxster S
Becker 1
Type 4462
Serial 15088261
24/99
CDP2081
Thanks a lot!
Help appreciated. I'm in the same boat as others, purchased vehicle without radio code, after disconnecting the battery I need the code.
'02 carrera 996
becker 1
cr220
s/n 25007995
4362
24/99
will provide vehicle vin if needed
thanks
'02 carrera 996
becker 1
cr220
s/n 25007995
4362
24/99
thanks
Try 7375
or
7371
Just had the original battery replaced in the 97 Boxster I bought a year ago and, of course, unable to locate the radio code card. The forums have been a great help in finding the s/n and I'm hopeful that I can get the 4-digit code so I can enjoy some tunes during the great summer weather.
'97 Boxster (German vehicle brought into US)
Radio is a CR-21 with a 6 disc changer in front trunk.
Model R1996
S/N V5002786
Hope you can help with a code.
Thanks.
Try 2565
or
2563
Thanks Loren. Unfortunately I tried 2560 through 2569 and no luck. Is there anything else I can try?
Model R1996
S/N V5002786
Thanks.
Try 2565
or
2563
Thank you, I am greatful for the tip. I will have to 'wait' to try the variances that you suggest in earlier posts.
The dealer I purchased the car from has yet to get back to me with any info (it has only been a day, but i got an answer here in an hour or so)
'02 carrera 996
becker 1
cr220
s/n 25007995
4362
24/99
thanks
Try 7375
or
7371
Hello
My SN is V5015965, CDR-210 from '98 Carrera S.
Thanks in advance.
Jeff
Try 1099
or
1097
Nope, neither worked. In fact, the dealer gave me Code 2101 based on SN and VIN and it doesn't work.
Any suggestions?
ok, followed the steps and this is wat i came up with:
type: 4462
cdr-220
srl#: w5006540
thanks u so much
Try 5188
or
5186
both didnt work :s
Man, I hate to ask since this radio-code thread has really overburdened Loren. But here goes...
Becker 1 CDR-220
4462
Y5053643
Can you help out yet another enthusiast trying to return tunes to his travels? Thanks, thanks, thanks.
Joe
St. Louis, MO
2001 Boxster
