I have a 2006 cayenne turbo s and when it rains and the brakes get wet I have about a 1-2 second delay in brake engagement when I depress the brake pedal. It’s is a pretty scary feeling on the freeway.
Any idea what is causing the brakes to behave like that?
When wet is a clue, look at the brake pad sensors including any speed sensors the ABS uses for each wheel. Wet is the direction it's telling you.
