My window won’t go up just down. I took off the door panel and then tried to raise it. It went up again so I thought the problem was solved so I put all the screws back. So later that day I noticed my window was half way down so I tried to raise it again and it wouldn’t raise. I opened up the door panel didn’t do anything else and it’ll raise again. I have no idea what could be the problem any guesses?
Check an d open the connector between the A pillar and the door for poor contacts, breaks and corrosion, including the relevant wiring in question up to the motor/control box.
