I have used the search function, but couldn't find anything. could someone tell me how to remove the center console, the one under the radio.
I have the original Porsche phone holder, and my interior is full leather.
thank you
the two side panels just pop out, it's best to pull out from the rea of those panels. then you can get to the screws on the side if you want to remove the entire center. if you just want to remove the tray or CD Storage they just pull straight out.
I'm sure Loren has a full diagram...
The only thing that I would add is that if you have the Bose option on a cabriolet, there are 2 torx screws (front and back) that hold the subwoofer to the right side of the upper console. The subwoofer must first be removed before you can get at the back upper screw holding the center console in place.
