Do you know what the correct tightening torque for the bolts holding the rotor to the aluminum hat is?
7.5 ft-lbs (10 Nm).
If the Brembo J slots are like the stock GT3 rotors then make sure you put them on the side or brake cooling will be non existent.
On GT3 rotors the cooling vanes (inside the rotor) face opposite directions. It is possible on a GT3 rotor to put them on the wrong side - creating little or no air flow through the rotor.
If the Brembo's are all the same then it likely does not matter. I would check and see if they are marked L and R or if between two they have different part numbers (front and front and rear and rear).
