I have a 997.1 S.
Recently the oil pressure readings have become abnormal.  Rather than indicating ~ 3 at idle and 5 at high rpm, it shows 5 all the time.  With electric power off, the reading is 0.  It jumps to 5 with electrical power on before starting the engine.
Is this a failure mode for the pressure sensor?
Tom
  • 2 months later...
What is considered normal behavior (indications) oil pressure gauge?
I am a new 2006 C2S owner and the oil pressure seems to be  pinned at 5 once I start the engine.
I have seen it drop to 3 when coming to stop at idle BUT it doesn't seem consistent.
I will gave to go back and check - have not noticed the indication with just electric.
It seems strange that normal (constant speed) driving would have it pinned at top of gauge
Welcome to RennTech :welcomeani:
Common problem, usually the sending unit going goofy.  Easy DIY.
  • Like 1
Just tested it with key turned to on (before start) and engine cold the gauge indicated about 3.
Sounds like it is time to replace the sending unit.
Thanks.
