I was resetting my service reminder when I noticed the following codes on my PDK box:
U0155: CAN timeout instrument cluster
U0146: CAN timeout gateway
U0418: CAN fault brake
1990: Positive engine torque intervention not possible
U0423: CAN fault instrument cluster
The car seems to run fine but I can’t clear the codes with the durametric and a battery reset didn’t help either. Any ideas?
Thanks for any pointers you may have. Hoping I’m not in for a $$$$ bill.
U0155 Instrument cluster, communication
Possible fault causes
- No power supply for instrument cluster
- Instrument cluster incorrectly coded
- Short circuit or open circuit in the CAN display
- Instrument cluster faulty (in most cases the cause is not the instrument cluster but incorrect coding!)
U0146 Gateway control unit communication
- No power supply for Gateway control unit
- Incorrect coding of Gateway control unit
- Short circuit or open circuit of CAN Drive
- Gateway control unit faulty (in most cases the cause is incorrect coding and not the Gateway control unit!)
U0418 Stop light switch
- Open circuit in signal wire from stop test switch
- Stop light switch faulty
U0423 Fault entry in specified control module
- Control module is incorrectly coded
- Periphery connected to specified control module is incorrect
- Control module faulty (in most cases the cause is not the control module but incorrect coding!)
1990 Positive engine torque intervention not possible
- Fault in CAN bus
- DME control unit detects engine fault
Thanks Loren. Is there a diagram of the CAN bus somewhere? It seems a common element in many. Perhaps the plug into the PDK is old/faulty?
