I am in the process of replacing the heater core on my C4S and when i removed the plastic scuttle at the bottom of the windscreen i found a thin, clear plastic pipe which comes up via a rubber grommet from the wheel arch to under the scuttle, however, it isn’t attached to anything. The end of it has been expanded so it would seem it has been attached to something but what it was i do not know.
Anyone  have any ideas?
^^Correct.  The battery vent tube for the old lead-acid batteries.  If you have upgraded to an AGM battery, the vent tube is not necessary.
