37 minutes ago, Bob Brooks said:
My 2017 Macan S has an erratic sensor for outside temperature.  Hoping this is a reasonable DIY replacement.
Bob in Houston
This is a rather common issue as the sensors do not read continuously, but reset themselves periodically, which is enough data for the vehicle but typically not for the driver, who often comments on them being inaccurate..  These sensors are typically mounted at the front of the vehicle, often in the front grill opening.  They are a simple plug and play device that retails for around $50..
