The topic regarding which brake fluid to use (Motul, SRF, Torque, Endless, etc) has been beaten to death, but nowhere have I been able to find a discussion on Porsche Classic Brake Fluid.
https://www.suncoastparts.com/mm5/merchant.mvc?Screen=PROD&Store_Code=P&Product_Code=SKUBFCLASSIC
The "Classic" brake fluid is recommended for Porsche's MY 2004 or older.  This is a different fluid than the current factory brake fluid.  https://www.suncoastparts.com/product/00004330552.html
Does anyone have any good info about this "Classic" and why I would want to use this for my 996 C4S vs the current factory fluid or one of the high performance brands mentioned above?
:welcomeani:
You can buy the same stuff on Amazon for much less.
Thanks for the tip!  Do you know why Porsche recommends a different brake fluid for their "classics"?
They used seals made of sn older material that are not always compatible with modern fluids.
Thank you.
