2003 cayenne 4.5 v8 non turbo automatic P1299 gateway
p1316 psm control unit
p1606 can timeout tcs/edtc
Repaired all wiring splices under carpet  (both sides)
replaced brake light switch
replaced battery
cleaned earth’s
swapped speed sensors from no issue cayenne
Warnings are
* brake proportioning
* 4x4 system faulty
* both digital and analog speedo not working
still have same problem I’m absolutely stumped
Edited by Newbiecayenne
Add more info
P1606 CAN Timeout, ASR/MSR
Possible fault cause
- No signals in PSM control module
Fault code 1316 PSM control module
Possible causes of fault
- No signal/communication (no signal from PSM control module on CAN drive)
- Faulty (fault value for wheel speed or distance pulses)
It looks like you have no CAN communication to the PSM controller.
Check the wiring at the controller and the connectors.
Ok I have power to the brake booster but it is still not working I disconnected the abs pump and I have exactly the same faults does that mean my abs pump is fried?
