Picked up a 2014 platinum (v6)with 60,000 miles
looking to do some routine maintenance
have seen the post on transfer cases so ordered some ravenel tc fluid and plan to do the change soon.
what should I use on plug threads when reinstalling?
also going to do oil change and brakes.
do I need a new drain plug for the oil change or possibly just a washer or can I reuse the plug?
brakes/ getting some squealing from the front. According to the maintenance records it is due for brakes.  I just ordered front.  I watched a couple videos and feel good about install, but confirming I need new wear sensors?
Is it likely the rears need replacing also?  Every other vehicle I have owned the fronts always wore out quicker but saw a bunch of porsche owners doing front and rear at same intervals
thanks!
Edited by Jdw1222
Got transfer cAse fluid changed.
Used the ravenel synthetic fluid.
old fluid was definitely black.
