Last night pulling in to the garage, I had a slight stumble followed by check engine light. P0491 and 2. Verified through scanner. Been reading lots of good troubleshooting posts. My question is can I drive it while working through trouble shooting if it’s not a quick obvious fix?
verified this am that the SAI pump cycles as normal at start up
Edited by BTERRY1
P0491 Secondary-air system
Possible fault causes
- Secondary air pump relay mechanically faulty (jams)
- Power supply for secondary air pump faulty
- Air duct cross section narrowed (pinched / blocked)
- Electric switch-over valve does not function
- Pneumatic switch-over valve does not function
- Leak in vacuum system
- Secondary air pump electrically or mechanically faulty
P0492 Secondary-air system
