On my CTT, the HID lights, when turned on, start out by dipping and then gradually raising up to predescribed level.
Some time ago, I noticed that the passenger side light does not do that, It just turns on and stays put, while the driver side headlight still goes through its startup routine.
I want to solve this and wanted to see if anyone knows what the problem may be.  Thank you for help.
Edited by ciaka
Probably either a loose connection or the leveling servo is out.  You should be able to activate the system with the Durametric or PIWIS and see what is going on.
