Hi All, 99 Boxster Base. My R window makes a knocking sound when its down and happens when closing the door. Upon inspection the front part of the window is hitting the front top "cable wheel" of the regulator. Is there a piece of foam or rubber missing from the top of the regulator. I can probably cure it by cementing a small piece of rubber to the top mount to avoid glass to metal contact. Thanks V
Fixed ....Window stop bumper was in the  lower (incorrect) notch on the rail.
