Does anyone know how much oil goes into  twin turbo V6 engine during oil chance?  I assume its the same Mobile one 5-40 synthetic that other engines use.  Also, I have found out durametric toolkit, which worked so  well in my 2012 Cayenne S doesn't work for 2016 models to reset the maintenance cluster. Anyone has experience using FOXWELL NT530 PORSCHE DIAGNOSTIC SCANNER TOOL?
Thank you,
Mike
Thank you Loren. Just curious where did you get this information from? 7L is the amount of oil that regular V6 engine takes. Does Turbo not add any additional oil capacity?
