I've verified this by 2 different methods and my speedometer reads 3-4 mph high.
One possibility I've explored is the difference between 17" tires and 18" tires.
I compared the two and at most, the difference is 1mph.
Anyone have this issue? Is there a way to recalibrate the speedometer?
Yes indeed - both my Boxster S and 911 Turbo have the same thing. About 3 MPH over actual speed. I took it into my dealer to fix and was told they had to be within 5 MPH - anything over / under they would fix. So I’ve just dealt with it. In my case it had nothing to do with tire size - all stock. I could see where that would affect it as well but a larger diameter would reduce the speed reading. I’ve just accepted probably all Porsche models around this period read higher than actual speed.
From my understanding, cars are made like that.  My digital and analog speedometer is consistently exactly 4 MPH faster than actual road speed.  Confirmed by many roadside radars.  I just adapt.
Edited by DBJoe996
The manufacturer's set the speedo high for two reasons: First, to keep from being sued if you get a ticket for speeding the speed is reading low; second, to run out your warranty faster.  And if you don't think the second is true, there was a class action suit by Honda owners after a TSB stating that was leaked to the public...………….
