My vanity mirror flap broke and I have purchased a new one from Suncoast Porsche. No instructions included. Any play by play instructions to offer,
You can pry the housing out of the visor using pry tools on the bottom. I then cut the power wires so I can get it out of the car. If your mirror is fine, you can carefully undo the tabs for it and remove it from the housing. I accidently broke my mirrors because I was rushing. Click the mirror into the new housing and solder the wired to hook it back up to the car.
Nothing to complicated, go slow and find all the clips
Sent from my GM1917 using Tapatalk
