Hello everyone
i have Cayenne s v8 2008 code p12a1 and p1026 showing COD I have started to  experience car stalling when I give it gaz for the pass month and now light Engine on and turn off the car can’t really drive with it and ideas what could be wrong
:welcomeani:
P12A1
Possible fault causes
  • Predelivery quantity or pressure in fuel low-pressure circuit too low
  • Fuel high-pressure system leaking
  • Fuel high-pressure sensor faulty
  • Fuel high-pressure pump faulty
P1026
  • Only if the value is below the lower limit:
  • Tank (almost) (driven) empty
  • If the value is below or exceeds the limits:
  • Quantity control valve faulty (in fuel high-pressure pump)
On 10/16/2019 at 7:31 PM, Loren said:
:welcomeani:
P12A1
P1026
so would this be the pump on the back of the cylinder?   or the fuel pump?
