So, when last we saw our hero, he was attempting to change out his old, yellowed and leaking expansion tank for a bright, clean new one. He removed the old expansion tank fairly easily after some yanking and twisting and turning. Installation of the new one, however, was destined to be a true test of character. He noticed that at first glance, the two tanks appeared similar yet, when compared side by side, there were slight differences, the primary one being a triangular section at the rear providing added capacity. He tucked all of the coolant and SAI hoses out of the way and commenced to attempt to put a square peg into an oblong hole. He undid the fuel rail feed/return lines and continued to push and twist and shove. He undid the motor mounts, lowered the engine as far as it would go, and continued the pushing, shoving and twisting. He removed the motor mounts altogether and attempted to wedge the engine sideways to obtain more space but, alas, there was no joy. Gentle readers, by this point the foul language had commenced, language so vulgar and cruel that decorum precludes its repetition on a family oriented forum. It is said, typically in hushed tones around a blazing campfire after several apertifs, that his head spun around 360 degrees on his shoulders, not unlike Linda Blair in "The Exorcist". Finally, he removed the upper black plastic bracket and, voila, the new tank fit where the old tank had been. Now our hero must deduce how to get the new tank past the bracket upon which it hangs in situs. In consideration of the amount of time, effort and foul language expended to this point, our hero was reduced to the most extreme of measures: surgery! He got out the dreaded cut off wheel and whacked off the first third of the black bracket, including the tabs, at an angle conducive to the tank's shape, and then there was joy and rejoicing, and candy!
  • Like 1
