Hi All, Just confirming that I CAN replace my brake fluid by using the Motive Pressure Bleeder on my 99 Boxster Base WITH TC (Traction Control), I've heard conflicting info regarding having to open valves in control unit w PTS2 and then some saying if you're bleeding after the control unit its fine. Thanks V
You ONLY need to activate the ABS/PSM control network if you have gotten air in it, otherwise just pressure bleed as normal.
OK....how do I insure I dont get air in it when doing the bleed? Thanks V
