 I hooked up My 2012 991 C2 PDK to the durametic and pulled  this  Code
Can Gateway Code  0401?
Does anyone know what this is?
     Only  Problem is my AC stop blowing cold.
thx.
Reply from  Durametic
Good Morning,
Thank you for writing. All fault codes displayed within the Durametric Software are defined by Porsche. Unfortunately, we do not have any further information regarding the cause of the fault. You may want to contact Porsche for further troubleshooting.
Please let us know if you have any further questions.
Regards,
Kevin Lewis
Durametric Software Inc
888-854-5523
Good Morning,
Regards,
Kevin Lewis
888-854-5523
Expand
Lame...
I would clear the code and see if it comes back.
I have a similar code coupled with a whine going on maybe attributable to the alternator failing?
Did you ever figure out what caused this error?
I know it was a long while ago but I have the same Durametric reading (0401) after changing my battery yesterday with a 'no break' charger attached.
Did you ever get to the bottom o it?
Did you disconnect the new battery and reconnect?
Cheers
John
