On a 99 Boxster, I am experiencing an intermittent non-crank problem. I have replaced the ignition swith, bypassed the clutch pedal switch, replaced the DME and starter relays in the trunk. I also tested the starter itself, it works when you put power to it, sometimes there just is no power getting to it. Any other ideas?? :lightbulb:
