Thanks in advance for your help. I have a new 2004 996 C4S with PSE installed at the dealer. I did the mod where I took out the relay marked abgasklappen and I cut the right diode in the right place. the cut out no longer cuts in but the switch on the dash no longer works to make it quiet when I want? Any one have anything like this happen? In the instructions it says the switch will still work? Thanks
