My ctt lately has been acting up.
When I drive it, all doors lock as requested by settings.
When I park and open front driver door, the trunk wont get unlocked as expected.  I have to go and open one of the rear doors, which will automatically unlock the trunk lid.
Also, the easy entry/drive system not acting right.  The seat wont slide into place when I start the car as expected.
Someone told me that there is a switch inside the driver door, which detects door open/close, and is the reason that the entry option plus trunk lid unlocking dont work.
They had that switch replaced in front door.
I have no idea which switch they are talking about.  I wanted to find out what switch they are talking about, so I can get it swapped out.  The symptoms can easily be explained by the switch faulty (since open/close not detected, seat/trunk actions wont happen as programmed).
Thank you for help in locating the component.  I am sure I can get PN for it from parts catalog. Just need to locate what part it is I need to replace.
