I had a similar problem recently.  I had to replace the alarm module.  About $150 and it is located on the middle of the firewall.  I am 6’1” and have long arms and I still found it a pain to reach it.  Several tutorials on the internet.  Follow the steps in exact order it will help (ask me how I know this).  The part is used on several cars over the years and is readily available.  Do not buy a used one.  They are known to fail with age.  I hope this helps.
  • Like 1
Why not spend the money and get the car scanned - then you will know the problem exactly - instead of guessing.
^ 100% agree. Why throw parts at the car without first checking the codes?
51 minutes ago, gabriel castillo said:
I use 3 scanner...incluid Piwis and no codes......
Was this a legal Porsche branded PIWIS or a China Knock-off?
There almost has to be a fault in the alarm system.
