I'd like to install the Traffic Pro 4763 in my '02 which has Bose and a CR220. Is the traffic pro plug and play, or will I have to splice wires to make it work?
Thanks.
You will have to splice 2 wires together to make the amp work but that takes just a few minutes. You are also supposed to run a reverse signal wire from the radio head to under the seat but that is optional.
Where did you get 4763 since that is the official Porsche version. We have been using 4773 which says Becker instead of Porsche.
Do I have to pay to view the TSB on this site? I was able to see a list of TSB including 9112 but don't see anything to click on.
I suppose the same wiring procedure can be used to connect an aftermarket HU to the Bose system that is not MOST (MY02). I am interested in adding Eclipse nav to my Bose.
Haven't purchased it yet. Didn't know the 4763 was hard to come by.
