Hello Guys,
I got myself a 2009 C2S convertible a few months back. Checking the PCM version it shows version V. I would like to get the latest version available because the iPhone disconnects from time to time when using the iPod connection.
I don't have map navigation and don't want to pay for it.
What is the best way? I there a DIY method to update only the firmware of the PCM?
If you haven't got navigation, tI can't see any reason why you couldn't update the firmware yourself, with the using update DVDs.  (If you had navigation, the old maps wouldn't work after the update).
What I can't work out is what you mean by Version V.  If you press INFO and SOURCE at the same time, it should show a numeric version number.  Something like 2.20.
Thanks Richard, do you know where i can find the update DVDs? I'll check again for the version but i used the PCM menu to get it: INFO > Options > PCM Settings > Display > Software Version
  • 11 months later...
