hello i have a dtc 0258 says shift solenoid valve(s1) OPEN CIRCUIT/SHORT TO B+ does anybody know where this solenoid is located?
the truck wont start and when i try to crank it the D is highlighted i cleared the check engine light and it will say P but if i try to crank it
the D will be highlighted again has anybody had this happen if so how did you fix it?
